Cloudflare cannot scan my DNS records. I’d like to get an SSL Certificate from Cloudflare and use their offered free services but suddenly, I’m stuck about this DNS Records. I don’t know what to input. I already dig some research but no answer. And all instructions from our knowledge base section, it’s not enough. Please help. @Admin
Kindly mention you Domain Name so I can Help other wise there is a main domain of every account like something.epizy.com or something.rf.gd
just point your domain toward your main domain using CNAME records!
@mauwiks said:
I cannot configure my own DNS to Cloudflare since I they cannot scan my records from the origin host which is I believe, our team in here.
So what happens when you start the record scan? You click the button and then what? The page stays exactly the same? It starts to look for the DNS records but it comes up empty? Cloudflare shows you an error page?
Even if you may say that “nothing happens” and “they cannot scan my records”, there are still plenty of observations you could share which might help clear this up.
Why would you need to put your dns records?
If you have installed Cloudflare on your site through 1-Click Cloudflare Enabler then it is immediately set-up and you can select SSL(which I recommend Full,because Flexible sometimes creates issues) and it will be installed in a few hours.
Full is recommended but Flexible will also work if you know how to properly code or develop a site!
Where about scanning DNS records @Admin already stated that we can change IP anytime without notice thus recommended to set CNAME record instead of A records!
