How to upload files with FTP
The best and most reliable way to upload files is to use FTP. To upload files with FTP, you will need to following:
  • Your FTP username
  • Your FTP password
  • The FTP hostname
  • An FTP client
You can find your FTP username, password and hostname in the client area under the FTP Details section. The FTP password is the same as your hosting account and control panel password, which is different from the password for the client area. If you like videos better then text guides, you can find one at the bottom of this tutorial.
For this guide the FileZilla FTP client is used. FileZilla is a popular free FTP client available for most common operating systems. But most other FTP clients can be used as well.
Setting up the Connection
  1. Open FileZilla
  2. Open File > Site Manager
  3. Click New Site
  4. In Host, type the name of the FTP server: ftpupload.net
  5. From the Logontype dropdown select Normal
  6. In User, type your username (eg. epiz_12345678)
  7. In Password, type your password
  8. Click OK
You have now just saved your connection information in FileZilla. If you want you can open Site Manager again and click on New Site under Select Entry to change the name from New Site to something meaningful like, you.example.com. That setting may help you to identify the account more easily.
Transferring Files
  1. Open FileZilla
  3. Click the site you want to connect to under Select Entry
  4. Click Connect
You should now be connected to your FTP account and see your files on the right and on the left, are files on your computer.
Using these two views you can upload and download by drag and drop by selecting files you want to upload from the left and dragging them to the right and vice-versa for files you want to download.
Keep in mind, if you have multiple sites on your account such as sub-domains or domains, you should always upload into the appropriate location for those sub-domains or domains (eg. /example.com/htdocs or /example.epizy.com/htdocs)
Removing Files
  1. Right-click on the files/directories you want to remove
  2. Select Delete
Changing File/Directory Permissions
  1. Right-click on the file/directory
  2. Select File Permissions…
  3. Using the checkboxes set your new permissions
  4. Click OK
Remember, never go below 600 or you will not be able to make changes to the file yourself.
Video Tutorial
I don't know how to upload my code
How to build a new website
Getting started with a new web hosting account
Installation failed: There has been a critical error on your website
How to backup your website
How do I upload an HTML shopping site from my computer to infinity?
How to upload the completed website to the host?
Error login in to filemanager
Uploaded my website template but my site is still offline?
Redirected to InfinityFree 404 error page
Permissions error
Problem in uploading files
I Can't Upload
The .htaccess file has been deleted and a 404 error message appears
File size > 1MB
File manager is not opening. This site is unreachable
How to upload big files / archives
Error! Could not read line from socket
Site Keeps Getting Redirect to ww01.site.com
Filemanager.ai sucks!
Help me mysql
Uploading error/Glitch
Jpa archive deleted after uploading
How to safely update to WordPress 6.1 (and fix your site if you didn't)
I can't access to my dashboard in wordpress
Files and folders are not being deleted, unable to install wordpress, stuck at 95%
Permissions Error
Could the administrator help me move a file
Cannot upload Wordpress zip file or directory
Domain redirects
Monsta FTP 077
My website does not open
I am downloaded vanillaforum can you help to upload it to my website
Folder not published to domain
How to fix a corrupted WordPress installation
Google drive to infinity free
Upload
404 not found
Help!
File Manager Not Working From 3 hours
Bootstrap - how to manage and publish?
When I upload zip and extract it it's not getting extracted
403 forbidden
Cannot see new theme in my site builder
I cant download a backup of filemanager
Unable to install Elementor
10000 forum users celebration - special event
Site error
Site error
I cant create a zip Archive
So confusing
How do i use zip files with filezilla
