My website URL is:
http://rustyadventure.epizy.com
What I’m seeing is:
HTTP ERROR 500
I’m using this software:
WordPress
Additional information:
My website URL is:
What I’m seeing is:
HTTP ERROR 500
WordPress
I have no idea how to verify that
Did you follow my link? If you don’t want to follow it, from the same link I posted before:
To see what’s going wrong, you could try to enable PHP errors.
The easiest way to do so is by going to your control panel, then PHP Config -> select your domain name -> Alter PHP Directives -> set Display Errors to On -> click Alter PHP Directives. Now, try to reload the page and see if an error message occurs.
looks like a wordpress update crashed my site no idea how to go about this
Than you, hopefully that fixes it
To confirm it is fixed now … Thanks Again
Hi @aRustyAdventure
I would ask you to choose a post that carries a solution (click on 3 dots)
and then mark it as solution
Because it means a lot to the one who helped you
