What I’m seeing is: I changed my url from http://aashnikitchenware.ga to https://aashnikitchenware.ga in softaculous wordpress setting. Now the website shows site can’t provide a secure connection. now even wp-admin page is not loading… please help me
If you don’t want SSL through Cloudflare, and also don’t want to let Cloudflare connect to the server through HTTP only, which will be less safer, and also causes redirect loops with some configurations, please read this article to see more about the new SSL feature on the Client Area:
Try to request an SSL certificate from the Client Area and install it on the “SSL/TLS” section of the Control Panel for your domain by following this article from “Installing an existing certificate” to stop this from happening, or change the WordPress URL from HTTPS to HTTP by following this guide:
Go to your Control Panel, then click on “MySQL Databases”.
Click on “Admin” near the database you want to go to phpMyAdmin.
Search for a table named wp_options (it may also vary depending on the WordPress installation), and click on it.
Edit the siteurl and home values to have the HTTP version of your domain (for example, https://yourdomain will become http://yourdomain) and execute the query.
