Status: Adres bepalen van ftp.epizy.com
Status: Verbinden met 185.27.134.11:21…
Status: Verbinding gemaakt, welkomstbericht afwachten…
Antwoord: 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
Antwoord: 220-You are user number 526 of 2900 allowed.
Antwoord: 220-Local time is now 10:18. Server port: 21.
Antwoord: 220-This is a private system - No anonymous login
Antwoord: 220 You will be disconnected after 60 seconds of inactivity.
Opdracht: USER rfgd_20479470
Antwoord: 331 User rfgd_20479470 OK. Password required
Opdracht: PASS ********
Antwoord: 530 Login authentication failed
Fout: Fatale fout: Kan niet verbinden met server
Status: Verbinding met server verbroken
Antwoord: 220-You are user number 520 of 2900 allowed.
Antwoord: 220-Local time is now 10:22. Server port: 21.
Opdracht: USER epizy_20479470
Antwoord: 331 User epizy_20479470 OK. Password required
Change the password -> no result
Help
