I need to get a webpage hosted. Can someone help me? This is my first time here at InfinityFree
You need minimum permission level of 600.
Your current permission is ok for now
KangJL,
Thank you so much for all the assistance you have given me. Is there anything else I should do right now to ensure my webpage gets seen on the Internet?
I see this now
You need to remove domain from hosting account then add it in again.
You will then need to copy files from /htdocs to privatemoneyforus.com/htdocs
I assume that means the webpage is not showing up properly. Is that correct?
yes
Okay. I will come back and deal with this tomorrow. It’s getting late. Meanwhile, can you leave me instructions on to remove the domain from my hosting account and then add it in again? Please.
Please see this thread
Hi KangJL,
Can you give me the link to the webpage where I will need to remove my domain from my hosting account and then add it in again? I did not see it mentioned in your discussion with Starlight.
I clicked on my domain name (privatemoneyforus.com) and was taken to the webpage indicated by the image below. It is not the webpage that has the contact form for my clients.
cpanel.epizy.com
KangJL,
Okay. I’ve removed the domain from the hosting account and then added it again on the webpage that is indicated by the image below. But I’m still getting the webpage I told you about in my recent post.
You mentioned that I will then need to copy files from /htdocs to privatemoneyforus.com/htdocs. Please explain to me how that is done.
You need to read this
Hi KangJL,
Using both the information you gave me and the video, I was able to successfully connect and transfer my files on the right of the FileZilla application to the server.
Hi KangJL,
I’m still not getting my webpage. This is the page I’m getting when I put the link to my webpage (privatemoneyforus.com) into my browser. What do I need to do to correct this?
Well you did not do that
As can see, privatemoneyforus.com/htdocs is not seen.
You need to copy your files to privatemoneyforus.com/htdocs
KangJL,
Okay. I must log back into the FileZilla application and then copy files from /htdocs to privatemoneyforus.com/htdocs. Since this folder is not seen, will I need to create it?
If you had re-added the domain correctly, the privatemoneyforus.com/htdocs folder should be created by default.
Can you provide a screenshot of the addon domain on the VPanel?
Please show directory structure of the filemanager as well.
KangJL,
Please look at the image below and tell me if I did this right. I see near the words “Remote site:”, /privatemoneyforus.com/htdocs. I then went to the folder on my computer where the files for my website were located. I highlighted them and transferred them to the right side of the screen into what should be the privatemoneyforus.com/htdocs folder.
Working now
You may want to rename web.html to index.html
KangJL,
I’m glad that it’s now working! Thank you for all your help! I’ll rename this following the instructions you gave me.
KangJL,
Okay. What must I do next? How do I make sure the buttons on my contact form is working properly?
