Iam trying to create SSL certificate. my ssl provider says upload one of his files to folder called acme-challenge in “.well-known”. I am uploading it but after 2 to 3 seconds it gets deleted. to check whether the file is there or not ssl provider told that check with your website link as website.com/.well-known/acme-challenge/file . so it redirected me to file not found page of infinityfree.net. How to solve this problem. PLS your help is much appreciated.
What is your SSL provider? If that’s Let’s Encrypt, InfinityFree blocks its confirmation due to the bot protection code.
are there any free providers other than sslforfree and letsencrypt
I use https://comodo.com/ for my own site. The certificate is free and easy to set up.
Hi
Did You upload them in htdoc folder of your domain?
