If Purchase ULTIMATE PREMIUM Plan Will I Get External MonogoDB Access
and other benefits I will get with MERN stack?
And even after purchase of ULTIMATE PREMIUM will I have to renew my SSL certificate after 3 months?
And Can Run Machine Leaning Models In Python?
I have honestly no idea.
If you want to know more about iFastNet’s premium hosting, please contact iFastNet. We don’t sell the premium hosting, we just advertise it, so we’re not an authoritative source on it.
Premium hosting has Let’s Encrypt integrated in cPanel to automatically renew the certificate for you without any interaction needed for you.
Machine learning models are INSANELY computationally expensive, and typically require a GPU to run well. You won’t be able to host that for $10 per month or less. Renting the GPU easily costs thousands per month.
If you want to start out with low costs, you could choose to use the AI APIs from OpenAI, Amazon, Google or another big provider. If you want to host it yourself, prepare to spend a lot of money. Because AI is expensive.
