hello guys
my site www.blogcunuz.ml/wp/
www.blogcunuz.ml directory listing i wanna see my site on homepage .ml
wordpress settings done what i need? change htaccess?
hello guys
my htcaccess
Options - Indexes
still dont working www.blogcunuz.ml
@blogcnuzz said:
hello guysmy site www.blogcunuz.ml/wp/
Just add Option -Indexes
on your htacces
Your Address is still www.blogcunuz.ml/wp/ but now www.blogcunuz.ml is redirecting to www.blogcunuz.ml/wp/ I suggest you to move your files from /wp/ to htdocs main folder then update your site name in PHPMYADMIN
SQL in wp_options change siteURL from www.blogcunuz.ml/wp/
to www.blogcunuz.ml
also do this with homepageURL from www.blogcunuz.ml/wp/
to www.blogcunuz.ml
Or
First update URL in General Setting in WP-Dashboard then move content from /wp/ to htdocs
The best thing to do is to check the installation settings BEFORE installing, so you don’t end up installing a website to a subdirectory when you don’t want to.
You could either reinstall the website (and this time make sure the Directory setting is correct!) or update the URL (which is more complicated).
Thanks guys i will try and write reply again
