Hi there wanderful people,actually I created a directory protection to protect a folder in my website with password and username I used for that .htaccess and .htpasswd method, its working fine but when I enter a wrong password the page redirecting me to https://infinityfree.net/errors/500/ error page.
and when I request again the url path where the protected folder is , it keep redirecting and showing the same https://infinityfree.net/errors/500/ page always.
I dont want this to happened and I dont wanna use system redirection for any 400,401,403,404,500,503 errors .
all what I want is stopping it , I dont want to use any redirection system in my website
thank you.
all what I want is stop it , I dont want to use any redirection system in my website
thank you.
Update you .htaccess
file!
thank you.Update you
.htaccess
file!
How?
.htaccess
file!How?
Please Delete this lines on the .htaccess file
DirectoryIndex index.php index.html index2.html
ErrorDocument 400 https://infinityfree.net/errors/400
ErrorDocument 401 https://infinityfree.net/errors/401
ErrorDocument 403 https://infinityfree.net/errors/403
ErrorDocument 404 Suspected phishing site | Cloudflare
ErrorDocument 500 https://infinityfree.net/errors/500
ErrorDocument 503 https://infinityfree.net/errors/503
And save the .htaccess file.
.htaccess
file!How?
ErrorDocument 503 https://infinityfree.net/errors/503And save the .htaccess file.
Hi emm I Cant this file is not writable, I tried that
.htaccess
file!How?
Where is that .htaccess file located?
You should edit the .htaccess file on your htdocs (public_html) folder.
in the root where you can see your domains folders /.htacess
Can you please give a screenshot when you try to save the .htaccess file?
seloved I removed the .htaccess file i dont know how this happened but I successfully remove it even when its not writable
And I recommend you to create another of it.
Since it’s a very good file for security on your website.
And also please insert this code to disable dir listing on your website.
Here is the code that you will only need to install on your .htaccess file to disable dir listing.
Options -Indexes
@UnknownLolz said:
@MigaWeb said:
seloved I removed the .htaccess fileAnd I recommend you to create another of it.
Since it’s a very good file for security on your website.And also please insert this code to disable dir listing on your website.
Options -Indexes
Thank you so much @UnknownLolz
Options -Indexes
Your welcome and glad to help.
Don’t hesitate to ask in the community forums of you want more support.
You need to create a new .htaccess
file in the htdocs directory of your message. It’s not possible to edit the main .htaccess for your account, but you can override all the rules in there in your own .htaccess file.
