My website URL is::- www.futureadda.rf.gd
What I’m seeing is::- Incode limit not reduce after delete everything from htdocs folder.
I’m using this software::- wordpress
Additional information:
You say you deleted everything. Then that pretty much defeats the purpose of a website.
As long as inode usage is under 80%, you should be fine.
Please note that the inode counter in the control panel is not a live counter. It doesn’t update immediately at any time a file is added or removed. It’s sampled every so often. If you check again a day later, the counter should be updated.
i am always having an INODE issue, however i never change anything,
can you please help me identify where are these inodes coming from?
thanks
Did you read this article already? It explains what the inode limit means and what you can do to limit it:
