I deleted thousands of files when it showed 100% inode usage. Then I deleted more than 10 thousand files. But it is still showing same percentage???
It took time to update! My recommendation is to try external file hosting provider to host large files and save inodes limit
O.K. thanks for your recommendation. (Sorry for wrong sentence and I don’t know how did I do that.)
Any external file hosting suggestion?
I really recommend you with Mega cause it gives you forever free 50 GB cloud storage, very generous I would say.
Or you could try Dropbox or Mediafire
@kiani007 said:
Any external file hosting suggestions, Google Drive, OneDrive, Mega, Douploads, Openload, BDUPLOADS, Dropbox, MediaFire, and many other some of them also pay you for sharing files
