Hai. I want to ask that my page login did not work. I run and test the page in my local its work. Can I know the limit for this site to save the data ?
Hello there,
Are you using a MySQL database to save your user credentials?
If so then please verify that you are using your correct MySQL database login credentials.
Also you might find this Knowledge Base articles helpful?
okay thank you for your response. Before this the page can login but today it cannot login. The problem is coding for connection. Thanks a lot
