My control panel not working
Username (epiz_33159508) or Website URL problogak.epizy.com
(my cpanel ot working )
Did you do this?
i don’t known vistapanel username and password
Can you login from client area?
These are shown in the client area
yes im login client area
Whenever I am clicking in cpanel, it is showing vistapanel after getting redirected.
what is the username and password of vistapanel tell me
Check it out yourself
can check my cpanel and fix vistapanel username and password
Reset your password
Wait 15 mins then login again
can you fix
Are you paying me? If not, do it yourself.
It is quite easy to fix this yourself.
In the client area, select your account, then “Edit Account”. Reset the accounts password.
After resetting. Wait 5 minutes, then try the green “Control Panel” button again.
