I believe that there is a mistake with vistapanel, because everytime I try to add the domain, it gives me an error saying that it has already been registered.
If you’ve used it on another MOFH host besides InfinityFree, and didn’t remove the domain before moving, then that would be why. They’re all on the same system.
I looked up the domain in the system and it appears that the domain is in use on an account at byethost22.com. You’ll need to remove your domain from there before you can add it here.
I looked up what I have registered and found one for byethost7.com (no add-on domain registered) and I couldn’t find anything on byethost22. com as it isn’t a valid domain.
