i recently installed my new php web crawler.
it is not forking fine why please check
What should it do but doesn’t do it? Or what does it do which it shouldn’t? What do you see?
“Website doesn’t work, please fix” is probably not going to get you any useful answers. People need specifics to be able to give specific answers.
sir same php application works on localhost but when i uploaded it to infinity it wont work
there might be some defect in it
in your server
It might be a problem on our servers, it might not. But whatever the cause of the problem is, I need more information from you about the problem. Even if there is a problem on our server, I can’t get it fixed if you won’t tell me what the problem is.
Remember that Web Crawlers are laggy when it uses too much resources and could result on account termination…
