Hello, I enter in my site and appear a error. In case the ERR_TOO_MANY_REDIRECTS error, how can I solve it? PLEASE HELP ME!!!
Well, the first thing to do is to figure out what’s causing it. A redirect loop is usually caused by:
- A bad redirect created through the control panel.
- A bad .htaccess configuration.
- A script configuration issue.
To figure out which one it is, you could try to:
- Delete any redirects in your control panel.
- Delete (or rename) your .htaccess file.
- Check if you can load any static files on your website (like images or other text files).
I have SSL, it’s a problem?
Possibly. If you have a .htaccess rule redirecting people to HTTPS but a website which is only configured to work on HTTP, that would explain this error. Wordpress notably redirects people to the URL configured in it’s database.
