Hi.
when i’m try to download a file in my terminal from my website in infinity, My website reposde a 403 error.
how can i fix it?
i need to access my website from terminal and download files (simply 10KB files)
Sir, i’m creating a website for my ShellScript.
Your system is very good, and protect my privacy but i need to access my user to download a 2KB text file into his/him system.
Your system is the best.
But this problem makes me unable to use it.
But is there a way to disable it?
Try to use CloudFlare, then select Full SSL, wait for 1-24 hours and tell me if this is solved.
Or, you can temporarily upgrade to premium hosting (free trial) and then do this.
From the knowledge base article:
Can I disable this security system?
No, this security system is mandatory on all websites and cannot be disabled.
What causes the ?i=1 suffix?
This extra URL parameter is caused by a browser validation tool we use to protect your website. The browser validator is a mandatory security system which ensures that your website can only be accessed through regular web browsers.
As always, the knowledge base has answers to almost all common questions.
I just thought it was the same… Because I had no problems when I used CloudFlare for example accessing my site through Mobile Apps…
