Username epiz_31418642
Website URL https://trybest.epizy.com/
This site can’t provide a secure connection
trybest.epizy.com sent an invalid response.
[Try running Windows Network Diagnostics](javascript:diagnoseErrors()).
ERR_SSL_PROTOCOL_ERROR
Website Not Running its not my network problem I upload all my website files on it but no working pls help
You need to install an SSL certificate on your domain.
If you’re using free hosting with your own domain or a subdomain, you’ll want to make your website work over HTTPS (SSL). Fortunately, InfinityFree provides all the tools you need to make it so. If you like videos better then text guides, scroll on down to the bottom of this guide.
This guide uses the control panel functions and the Free SSL Certificates tool provided by InfinityFree to get SSL up and running on your site.
Step 1: Set up the domain on your hosting account
The first thing to d…
i do this but not working bro
Click “Show” button (it is highlighted) then follow this article.
In order to get a padlock in the address bar in your website, you need to install an SSL certificate on your website. This article describes how to do that.
If you would rather watch a video, scroll down to the bottom of this article.
Installing an SSL certificate
The first step to install an SSL certificate is of course to get the SSL certificate. You will need to get your SSL certificate from a certificate vendor of your choice. InfinityFree also provides free SSL certificates in the client…
Its Says
The certificate can not be blankThe certificate uploaded is NOT for the domain name trybest.epizy.com ( was seen) .
Please go through the issuance process again, making sure to select ZeroSSL.
Done But Still Web Not Working
You have to press Upload Certificate.
yes i do but web not working yet
Clear your cache. Be patient. The internet is all about patience.
Yes, I already gave you one, but you neglected to pay attention to it.
which one i have to select
Don’t use external tools when you have it provided in the client area. Do you remember when you selected “Self-Signed” provider? Choose ZeroSSL instead.
https://app.infinityfree.net/sslCertificates/create/step1
Then, choose ZeroSSL.
