my website named http://www.x-tremeadventures.com/
is not working. I have updated name servers in godaddy account
but somehow it is not working
How to add your own domain to your account
How to point your domain name to InfinityFree nameservers?
When will my domain name start working?
well, I did change name servers to these ones
not to these ones
are they wrong???
Is this article isn’t enough to know how and what nameservers you should set or what?
Hi there everytime I try and click on my website www.choosegoldira.com - This pops up “00 Error, please check your php script / enable display_errors in your cpanel” Anyone know why or how I can fix it
@JustineNeedsHelpAgain create new topic instead of looking for help in someone else’s one
@jaynishshah said:
well, I did change name servers to these onesnot to these ones
are they wrong???
They are the same. They point to the same IP addresses, and all respond with the same information.
However, for some reason, your domain does not seem to return any records. Can you please try to remove the domain from your account, and then add it again (or create a new account for it)? Maybe that way the records will be installed correctly.
well, thanks a lot admin.
I deleted account and add newly full website
and now it is working…thanks a lot…can you tell me is php mail() function is working?
if yes why im not able to receive any email from website contact us page?
thank you
