Hello Everyone, I’m facing issue about that my sql database name does not change from epiz_27923231_XXX. Help me.
Thanks in advance
Regrades: Zaina
Thanks in advance
Regrades: Zaina
When you say it doesn’t change, do you mean the epiz_XXXXX doesn’t change?
The client area always shows the example value epiz_27923231_XXX
. That’s in part because there is no “the database name” for your hosting account. You can create databases yourself through the MySQL Databases section in the control panel with a name you specify. And you can create up to 400 of them.
