i have the css files js files and stuff i wanna use on my site
That sounds like basic HTML knowledge and not something specific to InfinityFree. You can find thousands of articles online explaining how to do that.
well is there a link to use the css files on infinity
Using CSS files is part of HTML. Any HTML or CSS tutorial will do: https://www.w3schools.com/css/css_howto.asp
As long as your HTML is correct and you’re using the right URLs for the CSS files, which hosting you use doesn’t matter.
