Can you add this:
to installer ?
Can you add this:
to installer ?
iFastNet and we can’t add it on the Softaculous Apps Installer, because it’s a paid software. If you’re trying to install a nulled software, please remove it immediately as it is not supported in free hosting.
it’s free
Yes, it’s free, but you need to install it manually because iFastNet and we can’t add it on Softaculous. See here how to install Matomo On-Premise.
package over 19Mb ! i cannot upload so much? is’t it ?
You don’t need to upload the zip. Extract it from your computer and upload the files inside of the matomo folder on your htdocs, and with a folder called analytics created. Then use the MySQL databases section on the Control Panel to create a database, and go to your Client Area inside of the account with your domain in there, scroll down and click on Show/Hide to show the password. Go to yourdomain/analytics/ and follow the steps, remembering on the Database Server to specify the right server that should look like sql123.epizy.com, but depends on the account, then the full database name, that is on the form username_dbname, where username is the username that should like epiz_12345678 and the dbname is the database name you inputted in the database name, then the username and the password that is on the Client Area with the steps to show the password.
If software is removed from Softaculous, it’s typically either because it violates the terms of service or because it doesn’t work on free hosting.
You’re free to try and install Matomo yourself, but there was probably a good reason why it was removed, so please keep your expectations modest.
