I have completed the steps to get a free SSL certificate and activated it (i didn’t create it but the service send it to me). My website works if I type https://www… but when I want to download the WordPress and use the https URL it says that it doesn’t find a trust worth SSL certificate.
How can I fix this?
Won’t that affect my SSL certificate? I would need 2 diffrent name servers.
I had before 2 nameservers…from cloudfare and infinityfree and when i wanned to create a certificate it said i need to have only 1 nameserver(infityfree) if not the ssl certificate could have some problems or something
I did the steps again and now I guess works. The only problem is redirecting. If I type only my domain it says that the website is not safe but if I type https://… says that it’s safe.
I checked on my phone and it redirected to https so it worked fine, but not on pc.
I created page rule and added SSL-strict, Automatic HTTPS Rewrites: On and on SSL/TLS is set on full(strict).
But I don’t know how to clear cache And WordPress was installed when the certificate was already maid
I have installed a plugin **Really Simple SSL and now it works. It still says that some stuff needs to be fixed but the main problem is gone.
Thank you for your help!!
