epiz_30741898
This site can’t be reached
I changed my domain nameservers to ns1.epizy.com and ns2.epizy.com but still my domain doesn’t work please help
(My domain is a .com domain)
epiz_30741898
We can’t help you if you don’t provide information.
Since you did not provide enough info, maybe registrar issue?
Take note
Ok now it says "This site doesn’t work (Error 500)
I see a white screen. What is it supposed to show?
An online shop (PrestaShop)
When I try the website through a subdomain it takes a bit of time to load but that’s because it is 361.1 mb in the softaculous store.
Ok now it just has the classic 404 page lol
So how do I fix it?
I just checked your site, but it seems to be working fine from here. Can you please clear your browser cache and check again?
It looks fine because for a TEMPORARY basis, I have to use GitHub pages and a stupid static version. Do you guys have like a CNAME or any otherDNS record instead of nameservers because nameservers don’t really work
Like an A record or smth
The nameservers work just fine.
In fact, you have not even set them up yet. You need to set up the nameservers to ns1.epizy.com and ns2.epizy.com, then wait 72 hours for changes to take effect.
And to answer your question, no. You must set the nameservers to add your domain to your account.
I set them up earlier but I removed them because it didn’t work
Don’t remove them. DNS changes can take time to sync. Set the namservers back, and don’t touch them. After 72 hours (~3days) you will be able to add the domain to your account. The more you add and remove and change them, the longer it will take.
Read the article I linked above to learn more.
it looks like its working (for me anyway) but may take a little longer for all name servers to sync up
In order to use IF, you need to set to correct nameservers.
Obviously you did not do so.
Please set
as @Greenreader9 had stated
