My domain redirects to this site. What’s going on? Thanks for the support ahead @Admin
Usually, that’s caused by DNS propagation. Just wait, your internet provider should pick up the change within a few days at most.
I still cannot open my site. please help
Here’s my Usename:
rfgd_19012036
Is your IP address correct? I see you’re using Cloudflare, can you please try pointing it to our nameservers directly to see if that solves the problem?
Same issue
Same issue
Your domain name is still pointing to Cloudflare. Can you please try to use our nameservers instead?
