EDIT: Unfixable. Why do I see ?i=1 at the end of a URL - Docs - InfinityFree Forum
I probably should have also mentioned, every time that PHP script gets used, it says JavaScript is required like its trying to load a page w/ JavaScript which is really weird.
@pushecx said:
Hi. I have a PHP script on my site, and for some reason, any URL I go to ends with &i=1, and it messes with my scripts. Is there a way to remove that? It happened before I uploaded any files as well.
Have you checked the KB article?
As far as I understand you on this.
The php scripts need javascript to work for example you have a php that wants to call a javascript file to make your php file make mobile responsive or anything that request a js file.
My bad, I just saw that. Darn. Thanks for the quick reply!
