Hi,
phpMyAdmin is not opening from control panel.
Website IP is 185.27.134.138 and hosting volume is vol15_6
Is anybody facing same issue?
Thanks,
Sandeep
Hi,
Thanks,
Sandeep
I think the hosting servers are down, as the cpanel too doesn’t work.
cPanel is working for me.
But, when I click phpMyAdmin, it takes a lot of time to show next screen. When it finally shows up, I click “Connect Now” button and it bombs.
Yes same problem here…
It’s up now.
I had the same problem last Saturday too.
Does any weekly maintenance or process run on Saturday?
Have you guys experienced the same?
Thanks,
Sandeep
No, but it may be so. Nothing as such from an official source. Downtimes are rare but very possible anytime. In the past some downtimes have been very bad with huge data losses, some on the other hand didn’t affect the systems.
The hosting system went down. It started with just the database servers, but spread quite quickly. It has been fixed now.
