I created a database via cpanel but cant see it in my phpmyadmin server. Why is that?
Also, I noticed the following message:
The phpMyAdmin configuration storage is not completely configured, some extended features have been deactivated. To find out why click here.
when i click it gives me following message:
$cfg[‘Servers’][$i][‘pmadb’] … | not OK [ Documentation ] |
$cfg[‘Servers’][$i][‘relation’] … | not OK [ Documentation ] |
General relation features: Disabled | |
$cfg[‘Servers’][$i][‘table_info’] … | not OK [ Documentation ] |
Display Features: Disabled | |
$cfg[‘Servers’][$i][‘table_coords’] … | not OK [ Documentation ] |
$cfg[‘Servers’][$i][‘pdf_pages’] … | not OK [ Documentation ] |
Creation of PDFs: Disabled | |
$cfg[‘Servers’][$i][‘column_info’] … | not OK [ Documentation ] |
Displaying Column Comments: Disabled | |
Browser transformation: Disabled | |
$cfg[‘Servers’][$i][‘bookmarktable’] … | not OK [ Documentation ] |
Bookmarked SQL query: Disabled | |
$cfg[‘Servers’][$i][‘history’] … | not OK [ Documentation ] |
SQL history: Disabled | |
$cfg[‘Servers’][$i][‘designer_coords’] … | not OK [ Documentation ] |
Designer: Disabled | |
$cfg[‘Servers’][$i][‘recent’] … | not OK [ Documentation ] |
Persistent recently used tables: Disabled | |
$cfg[‘Servers’][$i][‘table_uiprefs’] … | not OK [ Documentation ] |
Persistent tables’ UI preferences: Disabled | |
$cfg[‘Servers’][$i][‘tracking’] … | not OK [ Documentation ] |
Tracking: Disabled | |
$cfg[‘Servers’][$i][‘userconfig’] … | not OK [ Documentation ] |
User preferences: Disabled | |
Quick steps to setup advanced features:
- Create the needed tables with the
examples/create_tables.sql
. - Create a pma user and give access to these tables.
- Enable advanced features in configuration file (
config.inc.php
), for example by starting fromconfig.sample.inc.php
. - Re-login to phpMyAdmin to load the updated configuration file.
Is this the problem that is preventing me from not seeing any databases? if yes, how do i solve it?
