Hi,
I am a freelance web developer.
I would like to host multiple static websites (may be more than 3 sites) (no need PHP/MySQL) for small business.
Which plan should I use?
I will really appreciate for your advice
Hi,
Well as this is a static website you can try these below,
*netlify.com
*https://drv.tw
*fast.io
*github.io
@johndoemm
Hi and welcome to the forum
If your question is related to the InfinityFree free vs premium
for a start you choose free
and if that later becomes insufficient then you can easily switch to premium
You can host an unlimited number of domains/websites on a single hosting account (you get three accounts), however hosting multiple sites on one account increase the risk of hitting resource limits.
So you’d better split them by 3 accounts (this is more recommended for dynamic pages) .
Thanks for your advice.
