PLEASE HELP ADMIN… THANK YOU
im using xampp then what script/syntax/code should i copy to put in .htaccess
to run my site my .htaccess is empty code… i just create the file theh put in my htdocs.
im using index.php
im using index.php
HTTP ERROR 500 means that your website code is crashing. The exact way to fix this depends a lot on why the code is crashing, but this article should help get you started in figuring it out: https://infinityfree.net/support/http-error-500/
