CREATE DATABASE `twitter` /*!40100 DEFAULT CHARACTER SET utf8mb4 */;
USE `twitter`;
CREATE TABLE `data` (
`name` text NOT NULL,
`value` text NOT NULL
) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4;
INSERT INTO `data` (name,value) VALUES
('notice','');
CREATE TABLE `reports` (
`id` int(11) NOT NULL,
`bweet` int(11) NOT NULL,
`reporter` int(11) NOT NULL
CREATE TABLE `timezones` (
CREATE TABLE `tweets` (
`id` bigint(20) NOT NULL,
`content` text NOT NULL,
`user` text NOT NULL,
`timestamp` int(8) NOT NULL,
PRIMARY KEY (`id`)
CREATE TABLE `users` (
`id` int(8) NOT NULL AUTO_INCREMENT,
`fullname` text NOT NULL,
`email` text NOT NULL,
`username` text NOT NULL,
`timezone` text NOT NULL,
`password` varchar(255) NOT NULL,
`flags` int(11) NOT NULL DEFAULT 1,
`data` text NOT NULL DEFAULT '{}',
`bio` text NOT NULL DEFAULT '',
`location` text NOT NULL DEFAULT '',
`web` text NOT NULL DEFAULT '',
PRIMARY KEY (`id`)
Database names are always prefixed with your account username. So if you created a database with name twitter, the actual database name will be epiz_30479882_twitter.
