i accedently deleted Wordpress Files and now it is not working pls help me
You should have a backup and then upload everything.
As stated in the Control Panel, IF does not provide backups, you must. If you don’t have a backup, and the files are no longer visible on the file manager, you will have to re-start from scratch. Hopefully you will learn the important lesson of taking a backup. Good luck.
