I would like to know if I point to the domain server I obtained from a website hosting and point to these servers: ns1.epizy.com
ns2.epizy.com manage to have the domain changed without any further action? Thanks in advance
If you want to switch from one domain to another domain (including from a free subdomain to a custom domain), it takes a bit more effort than just updating the nameservers.
After updating the nameservers, you can add the domain name to your hosting account. You can add it through the Addon Domains or Parked Domains section. The former is useful if you want to create separate websites, the former is if you want to show the same content on both domains.
After adding the domain, you may also need to update your website configuration to use the new domain name. Whether this is required or how this is done completely depends on the software you used to build your website.
