username: epiz_28647637
website: a11i.eu
ERR_SSL_PROTOCOL_ERROR
I am using free hosting plan and have a problem setting up the SSL/TLS.
I generated a new “Let’s encrypt” certificate using the https://app.infinityfree.net/ssls tool and got a private key and certificate. Successfuly uploaded the key and the certificate in the cpanel. However the when I tried to open my domain https://www.a11i.eu with Chrome I got the following error: ERR_SSL_PROTOCOL_ERROR
I tried to diagnose the problem with openssl
openssl s_client -connect a11i.eu:443
CONNECTED(00000003)
139810635650304:error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error:../ssl/record/rec_layer_s3.c:1399:SSL alert number 80
no peer certificate available
No client certificate CA names sent
SSL handshake has read 7 bytes and written 176 bytes
Verification: OK
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.2
Cipher : 0000
Session-ID:
Session-ID-ctx:
Master-Key:
PSK identity: None
PSK identity hint: None
SRP username: None
Start Time: 1621376327
Timeout : 7200 (sec)
Verify return code: 0 (ok)
Extended master secret: no
I verified that the private key is 2048 bits (with openssl rsa -in private.key --text -noout
I tested the certificate inside local nginx and hardcoded ip address of a11i.eu in /etc/hosts, and Chrome recognize the certificate as valid, so at this point I think the private key and the certificate key are generated correctly.
What could be the problem? Is there any additional step that I need to do in order to configure HTTPS?
Thanks
