I have tested HTML validation for a page but i get errors although the code is correct with no errors when i make validation by “Validate by direct input”.
Also the validation sees that the document is HTML 4.0 although it’s HTML5.
@MoonlightCapital said:
It’s InfinityFree’s bot blocking protection that affects the request.
So how to fix that?
I don’t know how this bot can be useful when it makes the code having some validation errors!
You could decide to not use a web based checker. Or just not care that much about W3C compliance. If the code is actually broken, you typically don’t need a validator to figure that out.
