Problem with my site
www.samothrakisnews.gr i cant connect check it please
Your website has an error:
You need to fix it before you can view your website
that im checking right now :S
Can you show me the php code in wp-config.php?
I think the code has no problem. The problem is the file location. Please check that the php file is in your htdocs folder.
is in htdocs
Both wp-settings.php and wp-config.php?
ye
That means the wp-settings.php may have problem so you cannot open it. Please also show me wp-settings.php code.
ok i take a back up older file now i have a plugin problem in line 45
Your php file has a lot of error…
Can you show us a complete code so we can help?
code of settings ?
All the line in the php file
<?php
  • Used to set up and fix common variables and include
  • the WordPress procedural and class library.
  • Allows for some configuration in wp-config.php (see default-constants.php)
  • @package WordPress
  • Stores the location of the WordPress directory of functions, classes, and core content.
  • @since 1.0.0
define( ‘WPINC’, ‘wp-includes’ );
// Include files required for initialization.
require( ABSPATH . WPINC . ‘/load.php’ );
require( ABSPATH . WPINC . ‘/default-constants.php’ );
require_once( ABSPATH . WPINC . ‘/plugin.php’ );
  • These can’t be directly globalized in version.php. When updating,
  • we’re including version.php from another installation and don’t want
  • these values to be overridden if already set.
global $wp_version, $wp_db_version, $tinymce_version, $required_php_version, $required_mysql_version, $wp_local_package;
require( ABSPATH . WPINC . ‘/version.php’ );
  • If not already configured, $blog_id will default to 1 in a single site
  • configuration. In multisite, it will be overridden by default in ms-settings.php.
  • @global int $blog_id
  • @since 2.0.0
global $blog_id;
// Set initial default constants including WP_MEMORY_LIMIT, WP_MAX_MEMORY_LIMIT, WP_DEBUG, SCRIPT_DEBUG, WP_CONTENT_DIR and WP_CACHE.
wp_initial_constants();
// Check for the required PHP version and for the MySQL extension or a database drop-in.
wp_check_php_mysql_versions();
// Disable magic quotes at runtime. Magic quotes are added using wpdb later in wp-settings.php.
@ini_set( ‘magic_quotes_runtime’, 0 );
@ini_set( ‘magic_quotes_sybase’, 0 );
// WordPress calculates offsets from UTC.
date_default_timezone_set( ‘UTC’ );
// Turn register_globals off.
wp_unregister_GLOBALS();
// Standardize $_SERVER variables across setups.
wp_fix_server_vars();
// Check if we have received a request due to missing favicon.ico
wp_favicon_request();
// Check if we’re in maintenance mode.
wp_maintenance();
// Start loading timer.
timer_start();
// Check if we’re in WP_DEBUG mode.
wp_debug_mode();
  • Filters whether to enable loading of the advanced-cache.php drop-in.
  • This filter runs before it can be used by plugins. It is designed for non-web
  • run-times. If false is returned, advanced-cache.php will never be loaded.
  • @since 4.6.0
  • @param bool $enable_advanced_cache Whether to enable loading advanced-cache.php (if present).
  • Default true.
if ( WP_CACHE && apply_filters( ‘enable_loading_advanced_cache_dropin’, true ) ) {
// For an advanced caching plugin to use. Uses a static drop-in because you would only want one.
WP_DEBUG ? include( WP_CONTENT_DIR . ‘/advanced-cache.php’ ) : @include( WP_CONTENT_DIR . ‘/advanced-cache.php’ );
// Re-initialize any hooks added manually by advanced-cache.php
if ( $wp_filter ) {
$wp_filter = WP_Hook::build_preinitialized_hooks( $wp_filter );
// Define WP_LANG_DIR if not set.
wp_set_lang_dir();
// Load early WordPress files.
require( ABSPATH . WPINC . ‘/compat.php’ );
require( ABSPATH . WPINC . ‘/class-wp-list-util.php’ );
require( ABSPATH . WPINC . ‘/formatting.php’ );
require( ABSPATH . WPINC . ‘/meta.php’ );
require( ABSPATH . WPINC . ‘/functions.php’ );
require( ABSPATH . WPINC . ‘/class-wp-meta-query.php’ );
require( ABSPATH . WPINC . ‘/class-wp-matchesmapregex.php’ );
require( ABSPATH . WPINC . ‘/class-wp.php’ );
require( ABSPATH . WPINC . ‘/class-wp-error.php’ );
require( ABSPATH . WPINC . ‘/pomo/mo.php’ );
// Include the wpdb class and, if present, a db.php database drop-in.
global $wpdb;
require_wp_db();
// Set the database table prefix and the format specifiers for database table columns.
$GLOBALS[‘table_prefix’] = $table_prefix;
wp_set_wpdb_vars();
// Start the WordPress object cache, or an external object cache if the drop-in is present.
wp_start_object_cache();
// Attach the default filters.
require( ABSPATH . WPINC . ‘/default-filters.php’ );
// Initialize multisite if enabled.
if ( is_multisite() ) {
require( ABSPATH . WPINC . ‘/class-wp-site-query.php’ );
require( ABSPATH . WPINC . ‘/class-wp-network-query.php’ );
require( ABSPATH . WPINC . ‘/ms-blogs.php’ );
require( ABSPATH . WPINC . ‘/ms-settings.php’ );
} elseif ( ! defined( ‘MULTISITE’ ) ) {
define( ‘MULTISITE’, false );
register_shutdown_function( ‘shutdown_action_hook’ );
// Stop most of WordPress from being loaded if we just want the basics.
if ( SHORTINIT ) {
return false;
// Load the L10n library.
require_once( ABSPATH . WPINC . ‘/l10n.php’ );
require_once( ABSPATH . WPINC . ‘/class-wp-locale.php’ );
require_once( ABSPATH . WPINC . ‘/class-wp-locale-switcher.php’ );
// Run the installer if WordPress is not installed.
wp_not_installed();
// Load most of WordPress.
require( ABSPATH . WPINC . ‘/class-wp-walker.php’ );
require( ABSPATH . WPINC . ‘/class-wp-ajax-response.php’ );
require( ABSPATH . WPINC . ‘/capabilities.php’ );
require( ABSPATH . WPINC . ‘/class-wp-roles.php’ );
require( ABSPATH . WPINC . ‘/class-wp-role.php’ );
require( ABSPATH . WPINC . ‘/class-wp-user.php’ );
require( ABSPATH . WPINC . ‘/class-wp-query.php’ );
require( ABSPATH . WPINC . ‘/query.php’ );
require( ABSPATH . WPINC . ‘/date.php’ );
require( ABSPATH . WPINC . ‘/theme.php’ );
require( ABSPATH . WPINC . ‘/class-wp-theme.php’ );
require( ABSPATH . WPINC . ‘/template.php’ );
require( ABSPATH . WPINC . ‘/user.php’ );
require( ABSPATH . WPINC . ‘/class-wp-user-query.php’ );
require( ABSPATH . WPINC . ‘/class-wp-session-tokens.php’ );
require( ABSPATH . WPINC . ‘/class-wp-user-meta-session-tokens.php’ );
require( ABSPATH . WPINC . ‘/class-wp-metadata-lazyloader.php’ );
require( ABSPATH . WPINC . ‘/general-template.php’ );
require( ABSPATH . WPINC . ‘/link-template.php’ );
require( ABSPATH . WPINC . ‘/author-template.php’ );
require( ABSPATH . WPINC . ‘/post.php’ );
require( ABSPATH . WPINC . ‘/class-walker-page.php’ );
require( ABSPATH . WPINC . ‘/class-walker-page-dropdown.php’ );
require( ABSPATH . WPINC . ‘/class-wp-post-type.php’ );
require( ABSPATH . WPINC . ‘/class-wp-post.php’ );
require( ABSPATH . WPINC . ‘/post-template.php’ );
require( ABSPATH . WPINC . ‘/revision.php’ );
require( ABSPATH . WPINC . ‘/post-formats.php’ );
require( ABSPATH . WPINC . ‘/post-thumbnail-template.php’ );
require( ABSPATH . WPINC . ‘/category.php’ );
require( ABSPATH . WPINC . ‘/class-walker-category.php’ );
require( ABSPATH . WPINC . ‘/class-walker-category-dropdown.php’ );
require( ABSPATH . WPINC . ‘/category-template.php’ );
require( ABSPATH . WPINC . ‘/comment.php’ );
require( ABSPATH . WPINC . ‘/class-wp-comment.php’ );
require( ABSPATH . WPINC . ‘/class-wp-comment-query.php’ );
require( ABSPATH . WPINC . ‘/class-walker-comment.php’ );
require( ABSPATH . WPINC . ‘/comment-template.php’ );
require( ABSPATH . WPINC . ‘/rewrite.php’ );
require( ABSPATH . WPINC . ‘/class-wp-rewrite.php’ );
require( ABSPATH . WPINC . ‘/feed.php’ );
require( ABSPATH . WPINC . ‘/bookmark.php’ );
require( ABSPATH . WPINC . ‘/bookmark-template.php’ );
require( ABSPATH . WPINC . ‘/kses.php’ );
require( ABSPATH . WPINC . ‘/cron.php’ );
require( ABSPATH . WPINC . ‘/deprecated.php’ );
require( ABSPATH . WPINC . ‘/script-loader.php’ );
require( ABSPATH . WPINC . ‘/taxonomy.php’ );
require( ABSPATH . WPINC . ‘/class-wp-taxonomy.php’ );
require( ABSPATH . WPINC . ‘/class-wp-term.php’ );
require( ABSPATH . WPINC . ‘/class-wp-term-query.php’ );
require( ABSPATH . WPINC . ‘/class-wp-tax-query.php’ );
require( ABSPATH . WPINC . ‘/update.php’ );
require( ABSPATH . WPINC . ‘/canonical.php’ );
require( ABSPATH . WPINC . ‘/shortcodes.php’ );
require( ABSPATH . WPINC . ‘/embed.php’ );
require( ABSPATH . WPINC . ‘/class-wp-embed.php’ );
require( ABSPATH . WPINC . ‘/class-oembed.php’ );
require( ABSPATH . WPINC . ‘/class-wp-oembed-controller.php’ );
require( ABSPATH . WPINC . ‘/media.php’ );
require( ABSPATH . WPINC . ‘/http.php’ );
require( ABSPATH . WPINC . ‘/class-http.php’ );
require( ABSPATH . WPINC . ‘/class-wp-http-streams.php’ );
require( ABSPATH . WPINC . ‘/class-wp-http-curl.php’ );
require( ABSPATH . WPINC . ‘/class-wp-http-proxy.php’ );
require( ABSPATH . WPINC . ‘/class-wp-http-cookie.php’ );
require( ABSPATH . WPINC . ‘/class-wp-http-encoding.php’ );
require( ABSPATH . WPINC . ‘/class-wp-http-response.php’ );
require( ABSPATH . WPINC . ‘/class-wp-http-requests-response.php’ );
require( ABSPATH . WPINC . ‘/class-wp-http-requests-hooks.php’ );
require( ABSPATH . WPINC . ‘/widgets.php’ );
require( ABSPATH . WPINC . ‘/class-wp-widget.php’ );
require( ABSPATH . WPINC . ‘/class-wp-widget-factory.php’ );
require( ABSPATH . WPINC . ‘/nav-menu.php’ );
require( ABSPATH . WPINC . ‘/nav-menu-template.php’ );
require( ABSPATH . WPINC . ‘/admin-bar.php’ );
require( ABSPATH . WPINC . ‘/rest-api.php’ );
require( ABSPATH . WPINC . ‘/rest-api/class-wp-rest-server.php’ );
require( ABSPATH . WPINC . ‘/rest-api/class-wp-rest-response.php’ );
require( ABSPATH . WPINC . ‘/rest-api/class-wp-rest-request.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-posts-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-attachments-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-post-types-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-post-statuses-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-revisions-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-autosaves-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-taxonomies-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-terms-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-users-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-comments-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-search-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-blocks-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-block-renderer-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-settings-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-themes-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/fields/class-wp-rest-meta-fields.php’ );
require( ABSPATH . WPINC . ‘/rest-api/fields/class-wp-rest-comment-meta-fields.php’ );
require( ABSPATH . WPINC . ‘/rest-api/fields/class-wp-rest-post-meta-fields.php’ );
require( ABSPATH . WPINC . ‘/rest-api/fields/class-wp-rest-term-meta-fields.php’ );
require( ABSPATH . WPINC . ‘/rest-api/fields/class-wp-rest-user-meta-fields.php’ );
require( ABSPATH . WPINC . ‘/rest-api/search/class-wp-rest-search-handler.php’ );
require( ABSPATH . WPINC . ‘/rest-api/search/class-wp-rest-post-search-handler.php’ );
require( ABSPATH . WPINC . ‘/class-wp-block-type.php’ );
require( ABSPATH . WPINC . ‘/class-wp-block-type-registry.php’ );
require( ABSPATH . WPINC . ‘/class-wp-block-parser.php’ );
require( ABSPATH . WPINC . ‘/blocks.php’ );
require( ABSPATH . WPINC . ‘/blocks/archives.php’ );
require( ABSPATH . WPINC . ‘/blocks/block.php’ );
require( ABSPATH . WPINC . ‘/blocks/categories.php’ );
require( ABSPATH . WPINC . ‘/blocks/latest-comments.php’ );
require( ABSPATH . WPINC . ‘/blocks/latest-posts.php’ );
require( ABSPATH . WPINC . ‘/blocks/shortcode.php’ );
$GLOBALS[‘wp_embed’] = new WP_Embed();
// Load multisite-specific files.
require( ABSPATH . WPINC . ‘/ms-functions.php’ );
require( ABSPATH . WPINC . ‘/ms-default-filters.php’ );
require( ABSPATH . WPINC . ‘/ms-deprecated.php’ );
// Define constants that rely on the API to obtain the default value.
// Define must-use plugin directory constants, which may be overridden in the sunrise.php drop-in.
wp_plugin_directory_constants();
$GLOBALS[‘wp_plugin_paths’] = array();
// Load must-use plugins.
foreach ( wp_get_mu_plugins() as $mu_plugin ) {
include_once( $mu_plugin );
  • Fires once a single must-use plugin has loaded.
  • @since 5.1.0
  • @param string $mu_plugin Full path to the plugin’s main file.
do_action( ‘mu_plugin_loaded’, $mu_plugin );
unset( $mu_plugin );
// Load network activated plugins.
foreach ( wp_get_active_network_plugins() as $network_plugin ) {
wp_register_plugin_realpath( $network_plugin );
include_once( $network_plugin );
  • Fires once a single network-activated plugin has loaded.
  • @since 5.1.0
  • @param string $network_plugin Full path to the plugin’s main file.
do_action( ‘network_plugin_loaded’, $network_plugin );
unset( $network_plugin );
  • Fires once all must-use and network-activated plugins have loaded.
  • @since 2.8.0
do_action( ‘muplugins_loaded’ );
ms_cookie_constants();
// Define constants after multisite is loaded.
wp_cookie_constants();
// Define and enforce our SSL constants
wp_ssl_constants();
// Create common globals.
require( ABSPATH . WPINC . ‘/vars.php’ );
// Make taxonomies and posts available to plugins and themes.
// @plugin authors: warning: these get registered again on the init hook.
create_initial_taxonomies();
create_initial_post_types();
wp_start_scraping_edited_file_errors();
// Register the default theme directory root
register_theme_directory( get_theme_root() );
// Load active plugins.
foreach ( wp_get_active_and_valid_plugins() as $plugin ) {
wp_register_plugin_realpath( $plugin );
include_once( $plugin );
  • Fires once a single activated plugin has loaded.
  • @since 5.1.0
  • @param string $plugin Full path to the plugin’s main file.
do_action( ‘plugin_loaded’, $plugin );
unset( $plugin );
// Load pluggable functions.
require( ABSPATH . WPINC . ‘/pluggable.php’ );
require( ABSPATH . WPINC . ‘/pluggable-deprecated.php’ );
// Set internal encoding.
wp_set_internal_encoding();
// Run wp_cache_postload() if object cache is enabled and the function exists.
if ( WP_CACHE && function_exists( ‘wp_cache_postload’ ) ) {
wp_cache_postload();
  • Fires once activated plugins have loaded.
  • Pluggable functions are also available at this point in the loading order.
  • @since 1.5.0
do_action( ‘plugins_loaded’ );
// Define constants which affect functionality if not already defined.
wp_functionality_constants();
// Add magic quotes and set up $_REQUEST ( $_GET + $_POST )
wp_magic_quotes();
  • Fires when comment cookies are sanitized.
  • @since 2.0.11
do_action( ‘sanitize_comment_cookies’ );
  • WordPress Query object
  • @global WP_Query $wp_the_query
  • @since 2.0.0
$GLOBALS[‘wp_the_query’] = new WP_Query();
  • Holds the reference to @see $wp_the_query
  • Use this global for WordPress queries
  • @global WP_Query $wp_query
  • @since 1.5.0
$GLOBALS[‘wp_query’] = $GLOBALS[‘wp_the_query’];
  • Holds the WordPress Rewrite object for creating pretty URLs
  • @global WP_Rewrite $wp_rewrite
  • @since 1.5.0
$GLOBALS[‘wp_rewrite’] = new WP_Rewrite();
  • WordPress Object
  • @global WP $wp
  • @since 2.0.0
$GLOBALS[‘wp’] = new WP();
  • WordPress Widget Factory Object
  • @global WP_Widget_Factory $wp_widget_factory
  • @since 2.8.0
$GLOBALS[‘wp_widget_factory’] = new WP_Widget_Factory();
  • WordPress User Roles
  • @global WP_Roles $wp_roles
  • @since 2.0.0
$GLOBALS[‘wp_roles’] = new WP_Roles();
  • Fires before the theme is loaded.
  • @since 2.6.0
do_action( ‘setup_theme’ );
// Define the template related constants.
wp_templating_constants();
// Load the default text localization domain.
load_default_textdomain();
$locale = get_locale();
$locale_file = WP_LANG_DIR . “/$locale.php”;
if ( ( 0 === validate_file( $locale ) ) && is_readable( $locale_file ) ) {
require( $locale_file );
unset( $locale_file );
  • WordPress Locale object for loading locale domain date and various strings.
  • @global WP_Locale $wp_locale
  • @since 2.1.0
$GLOBALS[‘wp_locale’] = new WP_Locale();
  • WordPress Locale Switcher object for switching locales.
  • @since 4.7.0
  • @global WP_Locale_Switcher $wp_locale_switcher WordPress locale switcher object.
$GLOBALS[‘wp_locale_switcher’] = new WP_Locale_Switcher();
$GLOBALS[‘wp_locale_switcher’]->init();
// Load the functions for the active theme, for both parent and child theme if applicable.
foreach ( wp_get_active_and_valid_themes() as $theme ) {
if ( file_exists( $theme . ‘/functions.php’ ) ) {
include $theme . ‘/functions.php’;
unset( $theme );
  • Fires after the theme is loaded.
  • @since 3.0.0
do_action( ‘after_setup_theme’ );
// Set up current user.
$GLOBALS[‘wp’]->init();
  • Fires after WordPress has finished loading but before any headers are sent.
  • Most of WP is loaded at this stage, and the user is authenticated. WP continues
  • to load on the {@see ‘init’} hook that follows (e.g. widgets), and many plugins instantiate
  • themselves on it for all sorts of reasons (e.g. they need a user, a taxonomy, etc.).
  • If you wish to plug an action once WP is loaded, use the {@see ‘wp_loaded’} hook below.
  • @since 1.5.0
do_action( ‘init’ );
// Check site status
if ( true !== ( $file = ms_site_check() ) ) {
require( $file );
die();
unset( $file );
  • This hook is fired once WP, all plugins, and the theme are fully loaded and instantiated.
  • Ajax requests should use wp-admin/admin-ajax.php. admin-ajax.php can handle requests for
  • users not logged in.
  • @link AJAX in Plugins « WordPress Codex
  • @since 3.0.0
do_action( ‘wp_loaded’ );
I doubt that this is a configuration issue, but rather an issue with missing websites. Maybe following this guide helps to fix them?
https://infinityfree.net/support/how-to-fix-a-corrupted-wordpress-installation/
the new wordpress installation not work, i use an old backup copy of my site and now work just now need to update it again. im not lost evrything anyway. thanks your help all :smiley:
