So I made a site and I requested a SSL Certificate for it and it says “Issued” but then it also says
“Status: No SSL Certificate was Found” What is happening?
Make sure you have copied the cnames and direction correctly then try again
It doesn’t let me see the cnames should i delete the SSL?
Can you show the SSL tab under CPanel, then the SSL tab in InfinityFree and CNAME records from CPanel?
Did u install the SSL?
If it says the SSL certificate was issued but not found on your website, it would usually mean the certificate hasn’t been installed yet.
After the certificate is created, you still need to install it manually on your hosting account so your website can actually use the certificate.
If you click the certificate, there is a link near the top of the page that explains how to install it.
