I need to enable allow_url_fopen and I believe I can do this through .htaccess using the following: php_value allow_url_fopen on
but I can not do that. The .HTACCESS asks you not to change it directly, and when I make another file and put the line, it just does not work. What could it be?
It doesn’t work because you can’t enable allow_url_fopen. That’s a very dangerous setting which you should not be using.
I understand the security holes and I still need to enable this. Is there really no way? That’s what I really need.
