Is it possible to create wildcard SSL using IF’s SSL Wizard? Thanks in advance for any answers. I hope all is well.
No, it’s not possibile to create wildcard SSL certificates using InfinityFree’s SSL wizard.
How would I be able to do this? Since the vPanel does have custom SSL/TLS page.
Wildcard SSL certificates are not supported on free hosting either, so you can’t do that. If you want to install a wildcard SSL certificate use Cloudflare or upgrade to Premium Hosting as it offers more features.
Thanks!
