#Hello, I see this 403 error on trying to change redirection in panel
Forbidden
You don’t have permission to access /panel/indexpl.php on this server.
Forbidden
Can you please follow the template and provide a domain? Also, is the “panel” folder within the “htdocs” folder?
This can happen if the URL you’re trying to add gets caught in a security filter.
Can you share what is the URL you’re trying to redirect to?
Alternatively, you can just add it by hand using .htaccess rules. Simply open the file called .htaccess
in your htdocs folder and add a line like this:
Redirect / http://example.com/your-target-url
