i have used infinityfree my website-http://rentnsale.epizy.com/
whenever i use after reloadin 2-3 times it shows Refused to connect error
earlier it was showing failed to connect to database
i fixed bye correcting database password can you please help me fast.
The issue is that the IP address your website is on is currently being targeted for a DDoS attack. Because of that, the IP address had to be disabled to prevent damage to the system as a whole. The issue is being monitored, and the IP address will be re-enabled as soon as the attack has subsided.
Note that this does not mean your website specifically is the target of the DDoS attack. We host a lot of different websites on specific IP addresses, so it’s likely that another website was the target instead, and this is just collateral damage.
