I have created a free account and have uploaded my Wordpress website and it is running great! However I am unable to receive any mail from it to my Domain registered email.
I registered the domain with UK2.net, I have updated the DNS to point to the NS for infinity but the last part I am struggling with. Do I need to change my MX records on my registrar to point to the Infinity mail server or do I have to add my registrars MX to Infinity so that I can receive email?
If you’re using our nameservers, you don’t need to touch the DNS settings at your registrar, they don’t do anything.
The MX record in our server should be configured correctly from the start. However, you can check the actual record in the MX Records section your control panel.
@momonzhie said:
yah me also, sir how to set mx? i’m unable to receive any email. hw to fix this sir ma’am?
@Drakhul said:
hello, em it says i need to set my mx record to mx.rf.gd but it still doesn’t work
To everyone here: if you want me to check your settings, YOU MUST INCLUDE YOUR DOMAIN NAME. 99% of the accounts are working fine best I can tell. If you want me to figure out why your website doesn’t work, I NEED TO KNOW WHICH WEBSITE IS YOURS.
As for how to set MX Records: there is a control panel section which is literally called MX Records.
DOMAIN----------------------------- MX RECORD
jqyhfcr2.epizy.com------------- mx.byetcluster.com. - i think this is the default?
zhed.cf------------------------------- mx.epizy.com. - the one I’ve create
@momonzhie zhed.cf is currently hosted by 000webhost.com, so there isn’t anything you can do from here.
@Drakhul The MX record for hybridgamesoftwork.rf.gd is configured correctly. You see “still throws errors”. What is throwing errors and what do the errors say?
