I am trying to set up free web hosting. I downloaded WordPress and get to the CPanel login, except it doesn’t work at all, no matter what username and password I put in. Any help would be greatly appreciated. Thanks (
If you log into the Client Area, all you need to do is click the “Control Panel” button. And unless you recently changed the Hosting Account password, all should work fine.
@lovebug What you are describing is the login to the Client Area, not cPanel.
And @michaelacaggi Why not just install Wordpress through Softaculous?
Welcome! The button in the client area will auto-login for you when you click it. If it does not work, please select “Edit Account” in the client area and change the account password. Wait a minute or two, then try again.
@lovebug, the cPanel password is not the same as your signup details. It matches the hosting account details.
Here’s what I do: I go to Softaculous → Click on my installations → Then click on my admin person button, and it either sends me to the cPanel login which does not work, or gives me an unsecured server error.
