I need to shift my name servers to the Premium DNS ones by sectigo. I have the server address ready but the last time I tried it did not go well. I apologise in advance but what all dns records will I have to copy and how can I know that it works.
@Xplod4432, Do you mean that you are moving away from InfinityFree to Sectigo or something? Pls elaborate more the next time!
In short, you’ll probably want to setup an A record for your base domain pointing it to your account’s Website IP (you can find it in the client area) and a CNAME record for the www subdomain pointing it to the base domain. That’s all you really need to add.
@admin but she wants change the namservers to sectigo and still use the hosting. An A records is all that needs to be edited.
Webiste and files shall stay on InfinityFree I just want to use nameservers of sectigo instead of epizy
Is there any way to check if it works the last time I tried I kept getting dns resolution error when I shifted and added A records
This must help
Whenever there is IP changed, A record has to be updated. With CNAME, you don’t have to do that
yes, totally agreed!
Cool!
Thank you everyone!
You could use a web based DNS lookup tool to get the IP address of your website. Something like https://www.dnswatch.info/ or https://digwebinterface.com/ works well for that. If you enter your domain name there, you should see the Website IP from the client area in the response.
If the DNS records are already setup at Sectigo, you could even query the Sectigo servers for the records before switching over. Digwebinterface can do this if you enter the Sectigo nameservers in the Nameservers box.
I would have checked it for you, but I don’t know the nameserver addresses of Sectigo.
btw out of curiosity, are changing the nameservers for SSL?
For ddos actually, other day I got spammed and all the bandwidth and hits were used up in 10 minutes
ohh I see that, thanks!
if you are paying for sectigo then better go with premium hosting ffrom iFastenet
Yeah kinda didnt plan it well, I’m new to hosting stuff so till subscription runs out ill have to shift there ig
if your account is suspended also or delted there is no way to recover. atleast take a backup every day or on weekly basis, it is a good practise
