https://manaschoudhary.ml
i use cloud flare and i have enable its ssl certificate also should i need to make sll certificate after than also in infinity free or the cloud flare will use it’s own.
U shd if u intend to use full mode SSL. If u dun like renewing SSL cert every 3 mths, use a self-signed cert which is gd for 10 yrs.
but the search engine will not show dangers sign
That’s bcos search engine does not know origin server is nt encrypted
You use this self signed certificate only between InfinityFree and Cloudflare.
Search engines only see Cloudflare’s certificate, not the this one.
ok thanks
