Website URL
Details
All the files are inside the htdocs folder and I have an index.html file with some other subfolders there. how can I let connect it to the index file?
Add this to your .htaccess :-
#Prevent Directory Browsing
Options -Indexes
DirectoryIndex index.html
In your .htaccess file, you define the following line:
DirectoryIndex first.html
This means that the server will look for a file first.html
. If it can’t find it, it will show a directory listing.
If you want to use index.html
instead, you can just remove this line from your .haccess file.
