since I started using this host I had only problems. Leaving aside the fact that my domain is often unreachable, or rather, sometimes it can only be reached by some browsers / devices. THE REAL PROBLEM IS MY SITEMAP (http://freefilmreview24.com/sitemap.xml)
Which means that google can’t reach the sitemap. Also if it works
Here the problem:
sitemaps are not so important if the google bot is not blocked (robots.txt)
because google is more trusting in the bot than in the sitemaps that people submitted.
It’s important that Google knows about your domain and you added it to the GSC.
Very soon the bot will come and dig through.
And your robots.txt is OK
Try to have only one plugin for SEO
Try again in a few days (GSC also has its problems)
i’ve tried to test some of my url, but all the times google console says that my url have problems and can’t be indexed, because they can’t reacg it… So i will wait 48h and see…
Sorry, but, to be sure: does my website files works? because some times on some browsers my website appears error 404 page of ifast net
check it please:
http://
