Sites not working on all accounts
epiz_31431321
epiz_33248824
epiz_33259719
I checked every site, it just loads endlessly, maybe certificates are to blame SSL?
Welcome
Please share the domain names that are having issues.
Thanks
https://stylesirenkiev.is-best.net/
https://fskinsex.is-best.net/
It looks like those domain names do not exist. Try removing them, then re-adding them in the control panel.
Also, please note that adult website are banned here.
God no … I have an understanding that the name I chose is not from the standard ones.
FSkinsEx
F - Fupep(My nickname)
Skins - Steam items
Ex - Exchange
If I delete them in the control panel, does this mean the loss of all data? … Maybe there is another option?
Those links to the sites that I provided you are present in InfinityFree and in the Control Panel
Not if you just remove the subdomains from hosting account.
Files and databases should still remain
I deleted it, and in an attempt to take it back
Control Panel: 504 Gateway Time-out
epiz_33259719 | stylesirenkiev.is-best.net
There is a domain in the control panel, but in InfinityFree absent
I see this
Make sure there is SSL cert installed
Ok… I did everything you said, after deleting the domain and re-creating it, I have this
ssl panel not have this doman…
Strange indeed…you may have to wait for admin to sort it out
I really hope so, because a lot of effort went into the sites …
The IP address stylesirenkiev.is-best.net is on, 185.27.134.99, was down. It’s back up now though!
I have a new problem
epiz_33259719
http://stylesirenkiev.is-best.net
изображение_2023-03-22_143812449
Your site is working from here now. I see you’ve been removing and re-adding the domain to your account. This likely resulted in bad DNS records getting cached on your end. Which means this article applies again:
