Fischer (RoyalRoleplay)
Not message but error on redirection…
Look: https://www.royal-rp.fr and take a look to the same but without “www” and https
Its like you have 2 different website, and the good website is with “SSL/Certificate”.
And all my sub domain don’t work with https: forum.royal-rp.fr
The domain has been buy on “ikoula” and transfeer on “planethoster”, and i’ve changed “nameserver” to “InfinityFree”.
Ok, so your domains do work and they do force you to go into https for royal-rp.fr , and `with your ssl for your subdomains, try with the InfinityFree SSL tool, app.infinityfree.net/acmeDomains , However i see your using cloudflare, so you need to follow How to install an SSL certificate - Docs - InfinityFree Forum as it is a bit different adding SSL here to subdomains, as you can’t add the whole certificate.
Also http://forum.royal-rp.fr has an issue, see this article, Debugging in WordPress – Documentation
Thx for fast reply.
I go check your link and see what i can do…
For forum, i have just install wp for test but i’ve got IPBoard, its a bit different.
Screenshot by Lightshot for SSL tool of InfinityFree… 1 day i wait
Wait i want to add SSL/Cercificate to subdomain
This part: Screenshot by Lightshot i add to cname, it say:
“Duplicated CNAME records detected for the CNAME hostname.”
Because: Screenshot by Lightshot
You have not added CNAME records for wiki.royal-rp.fr , you have added them for;
_acme-challenge.www.royal-rp.fr
_acme-challenge.royal-rp.fr
You need to change your CNAME records as so;
_acme-challenge.www.wiki.royal-rp.fr
_acme-challenge.wiki.royal-rp.fr
So i delete
and add
And that for all subdomains?
Yes but for every different subdomain you change wiki, say for adding in ‘test’ you would add the records;
_acme-challenge.www.{subdomain}.royal-rp.fr
_acme-challenge.{subdomain}.royal-rp.fr
This article may be of some use, How to create the CNAME records for free SSL - Docs - InfinityFree Forum
Like this: prnt.sc/thg6xu ???
I think it is good now…
That looks good yes, now go to app.infinityfree.net/acmeDomains and request certificates for;
tickets.royal-rp.fr
wiki.royal-rp.fr
upload.royal-rp.fr
forum.royal-rp.fr
** It may take up to 24-72 hours for the DNS to propogate and for the SSL tool to detect your cname’s **
Its good: prnt.sc/thgitw
No problem, thank you for the help! I return to you if i have any problem
system
Closed
July 29, 2020, 9:52am
13
